ICMP pinging.
Oct 03, 2006 4 Replies
Jump to replies (4)
Heya fellas,
I just noticed this last night after playing and configuring my PIX 501 for like 3 weeks. My problem is my LAN can not ping outside world. I can ping inside from outisde, but not vice versa. I did managed to get it to ping outside, but only if I added a specfic lines in my config, if by doing that my other service will not run(ftp,port 8080,3389,etc). Im going paste my config here, so you guru's can take a look whats really wrong with it. If I put these line back everything work, but we cannot ping outside of the LAN.
"access-group inbound in interface outside"( cannot ping outside, but all my serivces will run)
NOW THIS.
"199pix(config)# no access-group 103 in interface outside" "access-list 103 permit icmp any any echo-reply" (with this 2 lines, my LAN can PING outside, but none of my ftp,mail,web will run)
------- SNIP ------------- PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxx
passwd xxxxx
hostname 199pix
domain-name katapole
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.1.13 Elfa
access-list inbound permit tcp any interface outside eq 8080
access-list inbound permit tcp any interface outside eq smtp
access-list inbound permit tcp any interface outside eq 3389
access-list inbound permit tcp any interface outside eq ftp
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.2 255.255.255.255 inside
pdm location 192.168.1.0 255.255.255.255 outside
pdm location Elfa 255.255.255.255 inside
pdm location 192.168.1.17 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface 3389 192.168.1.2 3389 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 8080 192.168.1.2 8080 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface smtp 192.168.1.2 smtp netmask
255.255.255.255 0 0
static (outside,inside) tcp 192.168.1.2 smtp 192.168.1.0 smtp netmask
255.255.255.255 0 0
static (inside,outside) tcp interface ftp Elfa ftp netmask 255.255.255.255 0
0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 45
ssh timeout 5
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname ikendo
vpdn group pppoe_group ppp authentication pap
vpdn username username password *********
dhcpd lease 3600
dhcpd ping_timeout 750199pix(config)# access-list 100 permit icmp any any echo-reply
199pix(config)# access-group 100 in interface outside
199pix(config)# no access-list 102 permit icmp any any
199pix(config)# no access-list 103 permit ip any any
dhcpd auto_config outside
username admin password 1ZXpWLcm3C.25OQ/ encrypted privilege 15
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
add the global command "icmp permit any inside" Also add: access-list inbound permit icmp any any echo-reply access-list inbound permit icmp any any time-exceeded
Do I need to remove my old access-list, before I add these 3 lines in?
Does this look right to you guys?
global (outside) 1 interface access-list inbound permit icmp any any echo-reply access-list inbound permit icmp any any time-exceeded
You do not need to remove the old acl. The new will just add to the bottom of it. Not sure how or why you changed the inside ICMP command to a NAT statement. You should be adding 3 lines to your config. The first line allows ping from inside, the second line allows the ping reply to come back in, the third line allows you to do trace routes from inside to an outside IP.
conf t icmp permit any inside access-list inbound permit icmp any any echo-reply access-list inbound permit icmp any any time-exceeded exit wr mem
