Any suggestions on command?
How to I forward a port (3389) to a PC (192.168.1.5) in a NAT environment in Pix (6.2)?
Jul 28, 2005
Thanks. But do I need any access-list or "fixup protocols"? If yes, how do I put it?
Read the full replyThanks. But do I need any access-list or "fixup protocols"? If yes, how do I put it?
In article , swsw wrote: :Any suggestions on command?
static (inside,outside) udp XX.XX.XX.XX 3389 192.168.1.5 3389 netmask
255.255.255.255OR
static (inside,outside) udp interface 3389 192.168.1.5 3389 netmask
255.255.255.255In article , swsw wrote: :Thanks. But do I need any access-list or "fixup protocols"? If yes, how :do I put it?
You do not need any 'fixup'. You -will- need an access-list and access-group.
My memory of the details of PIX 6.2 is starting to fade a bit and the documentation is a bit weak on some points. My recollection is that if the packets will be addressed to teh PIX outside interface, that the ACL entry you would need would be similar to
access-list outside2inside permit udp any interface eq 3389
but you might instead need
access-list outside2inside permit udp any interface outside eq 3389
The documentation does not indicate that the 'interface' keyword existed in 6.2, but my recollection is that it did.
If you do not (or cannot) use the interface keyword in the ACL, then if your PIX's public IP is your only IP, the next choice would be
access-list outside2inside permit udp any any eq 3389
If the PIX does not recognize the 'interface' keyword in ACLs and you need to be more specific about the destination IP (because you have other IPs) and it is the Interface IP that you want the port to be forwarded for, then you could try
access-list outside2inside permit udp any host XX.XX.XX.XX eq 3389
where XX.XX.XX.XX is the pubic IP. This will NOT work properly in PIX 6.3!! (It also will not work properly in PIX 5.x, as PIX 5.x does not allow forwarding of PIX interface-IP ports.)
Whatever ACL entry you end up using, you will need
access-group outside2inside in interface outside
Note: you should check first with show access-group as you might already have an existing access-list on the outside interface.
