How to allow access through Cisco ASA
Oct 11, 2007 4 Replies
alexd
Yes. That's exactly how the ASA security model works. It's easier to work around if you use DNS [eg split views in bind].
Can someone help me with this.
We have an ASA doing NAT for our network. We have a webserver on our network.
Lets say the IP address for the wan port on the ASA is
206.123.123.123. When I am on the network, I cant seem to access the webserver by going to http://206.123.123.123. If however I am on my home network and on the internet, I can access the webserver http://206.123.123.123. The port 80 forwarding rule is in place and works fine.
So you see, for some reason, the ASA is blocking me when I am going out through it and back in.
This is what I have, I changed
access-list OutsideISP_access_in extended permit tcp any interface OutsideISP eq https access-list OutsideISP_access_in extended permit tcp any host
206.xxx.xxx.xxx eq www access-list OutsideISP_pnat_inbound extended permit tcp interface OutsideISP eq https interface InsideStaff eq https static (InsideStaff,OutsideISP) tcp interface https 10.55.5.11 https netmask 255.255.255.255
10.55.5.11 can be reached from the internet when I go to http://206.xxx.xxx.xxx,however, when I am on the 10.55.5.x local network and try to visit http://206.123.123.123 it doesn't work.
Is there a way to make it work?
visithttp://206.123.123.123it doesn't work.
There were a couple of ways you could do this on the old PIX's, nameley DNS Doctoring (6.2) and the alias commands.
I know the ASA suports DNS Doctoring but am unsure about the alias command.
Just do a search on cisco.com and you shoud find a number of helful articles.
HTH
Regadrs
Darren
why not just modify your *host* file on your windows box your using to browse on the internet (within the LAN/WAN of that router) .. eg
webserver 10.x.x.x
that way when your in your browser, you just type in webserver and you get in to your site (its a work around, but it does work)
