How can I set 2 routers with same network address ?
Mar 23, 2006 6 Replies
S
What file? Don't attach file when sending to newsgroups. Back up and explain what you are trying to do. * Free account sponsored by * * Encrypt your Internet usage with a free VPN account from *
I don't understand it please help me. I have no idea. Two routers are connected with hubs, and I can't ping from workstation "sys6" to "sun workstation" how can I ping each other ?
Please refer to below. It's "packet tracer 3.2" file representing my cisco lab configuration. Thanks.
*** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from
On 23.03.2006 21:50 jh3ang wrote
did you set the default route on both sys6 and sun workstation to the ip_address of the directly attached router? E.g.
if sys6 has ip address 192.168.42.1/24 and rtr_1 192.168.42.254/24 set
ip route add default via 192.168.42.254
Sorry, Here comes image files. These are router status and topology.
From the router (3600) can you ping both sys6 and sun workstation? Do they have default gateways or routes to the other network via the router?
Chris.
Yes, I can ping from 3600 to sys6, and from 3600 to sun. I'm gonna try again after "default gateway" setting, but first i have to find out how to configure defualt gateway -.-.
