HELPME: Prefered Routing using Dialer Watch.
Mar 18, 2007 2 Replies
Hi All,
Have you ever tried to implement dialer watch? Yes, I know this is not the best way to implement dial backup which most people will use floating route. However, for the sake of curiosity, I want to try to create a small scenario where two routers are connected using Frame Relay (FR) link and a dial backup whenever particular route is gone from the routing table.
However, I can get the BRI0 disconnected and while primary link is already up.
I've put the details about this scenario on
Appreciate your help.
You've got "stuff" going accross the link thus not allowing the idle timeout to happen. Do a log on the acl and find out what it is. Right off the bat, it could be CDP, should should disable that on the bri's.
I finaly got it working. If you keen, just visit the link
as I put 2 solutions for it.
It was not about the "stuff" but thanks anyway for your reply. I appreciate it!
