Help with NAT configuration on a Catalyst 6500 with no FWSM
Dec 06, 2006 1 Replies
Hello all,
So, here's my situation:
I have a Catalyst 6500 (with no Firewall Services Module) with a switchport interface (let's call it the external interface) configured with an ip address of 10.1.1.254 and a vlan interface (vlan 101) configured with an ip address of 172.16.1.254.
I have another switchport interface assigned to vlan 101 and a computer connected to that switchport with an ip address of 172.16.1.101 and the gateway set to 172.16.1.254.
I have a computer connected to the external interface with an ip address of 10.1.1.101 and the gateway set to 10.1.1.254.
I can ping from 10.1.1.101 to 172.16.1.101 and visa versa with no problems.
Now what I would like to do is set up NATing on the vlan interface such that any traffic coming from the 10.1.1.0 network looks like it's coming from the vlan interface itself (172.16.1.254) to the computers on the 172.16.1.0 network.
Can anyone help me out with this? I've searched the web for 6500 NAT examples but all the results I've seen so far deal with the FWSM. I've also tried to figure it out myself by looking at the 'ip nat' commands on the 6500 but just don't know where to start...
Thanks in advance!!!
This is no different from any other Cisco NAT.
int whatever-172.16.1.254 ! e.g int gi 4/7 ip nat outside
int whatever-172.16.1.0 ip nat inside
ip nat inside source list ACL.nat interface whatever-172.16.1.254 overload
ip access-list extended ACL.nat permit ip any any
If you fancy you could use a more restrictive ACL but it is not necessary since only the relevant traffic is considered for NAT anyway.
BEWARE:- If I recall correctly this will be CPU routed wich will give your
6500 the same performance as a 7200 ish.
