HELP!!! VPN to another network while behind Cisco 501 PIX
Dec 15, 2005 2 Replies
HELP!!! VPN to another network while behind Cisco 501 PIX open original image
I have a remote site currently using a DSL connection connected to a PIX 501 with a direct VPN connection back to the corporate office. My remote site needs to be able to connect (using XP VPN software) to another company's network. I can connect to their network if I am at home on my DSL connection but if I am behind my Cisco PIX 501 firewall I get an error 619. Anyone have any ideas? Any help would be greatly appreciated.
Current conf interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password XXXXXXXXXXXXXXXXXXX /e encryptXXXXXXXXXXXX passwd XXXXXXXXXXXXXXXXXXXXXXXX /e encryptXXXXXXXXXXXX hostname ABC-COMP domain-name ABC-COMP clock timezone CST -6 clock summer-time CDT recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 10.0.0.0 ABC-COMP access-list ipsecpeer permit ip 10.X.X.X 255.255.255.0 ABC-COMP
255.255.0.0 access-list ipsecvpn permit ip 10.X.X.X 255.255.255.0 ABC-COMP
255.255.0.0 access-list 101 permit icmp any any access-list 101 permit icmp any any echo-reply access-list 101 permit tcp any any eq 500 access-list 101 permit udp any any eq isakmp access-list 101 permit udp any any eq 1701 access-list 101 permit tcp any any eq 1701 access-list 101 permit udp any any eq 10000 access-list 101 permit tcp any any eq https access-list 101 permit tcp any any eq 4500 access-list 101 permit udp any any eq 4500 pager lines 24 logging on logging history debugging mtu outside 1500 mtu inside 1500 ip address outside 65.X.X.X 255.255.255.X ip address inside 10.X.X.X 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list ipsecpeer nat (inside) 1 0.0.0.0 0.0.0.0 0 0 access-group 101 in interface outside route outside 0.0.0.0 0.0.0.0 65.X.X.X 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local ntp server 192.X.X.X source outside http server enable http 10.X.X.X 255.255.255.0 inside snmp-server host inside 10.X.X.X snmp-server XXXXXXXXXXXXXXXXXXXXXXXXX snmp-server contact XXXXXXXXXXXX snmp-server XXXXXXXXXXXXXXXXXXXXXXXX snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp sysopt ipsec pl-compatible crypto ipsec transform-set XXXXXXXXXXXX XXXXX-XXXX XXXXX-XXXX crypto map vpn_map 20 ipsec-isakmp crypto map vpn_map 20 match address ipsecvpn crypto map vpn_map 20 set peer 67.X.X.X crypto map vpn_map 20 set transform-set XXXX crypto map vpn_map interface outside isakmp enable outside isakmp key XXXXXXXXXX address 67.X.X.X netmask 255.X.X.X isakmp nat-traversal 20 isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet 10.X.X.X 255.X.X.X inside telnet ABC-COMP 255.X.X.X inside telnet timeout 5 ssh timeout 5 management-access inside console timeout 0 vpdn group pppoex request dialout pppoe vpdn group pppoex localname XXXXXXXXXXXXXXXXXXXXXXXXXX vpdn group pppoex ppp authentication pap vpdn username XXXXXXXXXXXXXXX password XXXXXXXXXXXXXXXXX dhcpd dns 10.X.X.X 10.X.X.X dhcpd wins 10.X.X.X dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd domain ABC-COMP dhcpd auto_config outside terminal width 80 Cryptochecksum:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
If you mean PPTP when you say MS VPN, then the problem is with the pix not supporting PPTP passthrough. Sadly, everything but a PIX supports it such as the Linksys or Dlink router you have at home - even IOS supports it, but not the PIX.
However, there is hope - it's coming out in the next version.
The only workaround is to have a static one-to-one NAT with each inside host that needs VPN access to a public IP address. Also you will need a rule for PPTP (TCP 1723) going in both directions - Just having it from the inside --> out won't take care of it.
------------------------------------- Scott
Peter
