GLBP Check
Apr 30, 2008 2 Replies
GLBP Check open original image
I have setup GLBP to replace HSRP on my two host routers. However, they do not appear to be load balancing when I look at my network monitoring. All outbound traffic is using only one router. Can someone take a look at my configs listed below and see what I might be missing. I've also included the "show glbp" results from the two routers. Thanks.
interface GigabitEthernet0/0 description WAN_vlan ip address 192.168.4.32 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp duplex auto speed auto media-type rj45 negotiation auto no cdp enable glbp 10 ip 192.168.4.28 glbp 10 timers 10 40 glbp 10 timers redirect 600 7200 glbp 10 priority 254 glbp 10 preempt glbp 10 weighting 110 lower 75 glbp 10 weighting track 5 decrement 50 ========================================================== interface GigabitEthernet0/0 description WAN_vlan ip address 192.168.4.33 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp duplex auto speed auto media-type rj45 negotiation auto no cdp enable glbp 10 ip 192.168.4.28 glbp 10 timers 10 40 glbp 10 timers redirect 600 7200 glbp 10 priority 150 glbp 10 preempt glbp 10 weighting 110 lower 75 glbp 10 weighting track 5 decrement 50 ============================================================ ============================================================ MPLS-Host-RTR01#show glbp GigabitEthernet0/0 - Group 10 State is Active 5 state changes, last state change 07:53:20 Virtual IP address is 192.168.4.28 Hello time 10 sec, hold time 40 sec Next hello sent in 9.832 secs Redirect time 600 sec, forwarder time-out 7200 sec Preemption enabled, min delay 0 sec Active is local Standby is 192.168.4.33, priority 150 (expires in 32.896 sec) Priority 254 (configured) Weighting 110 (configured 110), thresholds: lower 75, upper 110 Track object 5 state Up decrement 50 Load balancing: round-robin Group members: 0015.629a.80e0 (192.168.4.32) local 0016.9d43.7ec0 (192.168.4.33) There are 2 forwarders (1 active) Forwarder 1 State is Active 3 state changes, last state change 07:54:00 MAC address is 0007.b400.0a01 (default) Owner ID is 0015.629a.80e0 Redirection enabled Preemption enabled, min delay 30 sec Active is local, weighting 110 Arp replies sent: 5 Forwarder 2 State is Listen MAC address is 0007.b400.0a02 (learnt) Owner ID is 0016.9d43.7ec0 Redirection enabled, 592.892 sec remaining (maximum 600 sec) Time to live: 7192.892 sec (maximum 7200 sec) Preemption enabled, min delay 30 sec Active is 192.168.4.33 (primary), weighting 110 (expires in 32.892 sec) Arp replies sent: 1 ====================================================================== MPLS-Host-RTR02#show glbp GigabitEthernet0/0 - Group 10 State is Standby 1 state change, last state change 07:18:59 Virtual IP address is 192.168.4.28 Hello time 10 sec, hold time 40 sec Next hello sent in 0.456 secs Redirect time 600 sec, forwarder time-out 7200 sec Preemption enabled, min delay 0 sec Active is 192.168.4.32, priority 254 (expires in 37.388 sec) Standby is local Priority 150 (configured) Weighting 110 (configured 110), thresholds: lower 75, upper 110 Track object 5 state Up decrement 50 Load balancing: round-robin Group members: 0015.629a.80e0 (192.168.4.32) 0016.9d43.7ec0 (192.168.4.33) local There are 2 forwarders (1 active) Forwarder 1 State is Listen MAC address is 0007.b400.0a01 (learnt) Owner ID is 0015.629a.80e0 Time to live: 7197.388 sec (maximum 7200 sec) Preemption enabled, min delay 30 sec Active is 192.168.4.32 (primary), weighting 110 (expires in 37.388 sec) Forwarder 2 State is Active 1 state change, last state change 07:19:29 MAC address is 0007.b400.0a02 (default) Owner ID is 0016.9d43.7ec0 Preemption enabled, min delay 30 sec Active is local, weighting 110
Who is a "client" for the GLBP? Do you have a single device who connects to these two routers? Then it will never work.
GLBP works only when you have multiple clients on Layer2 network. Basically, when Client1 goes to a gateway, GLBP gives MAC Address1, and when Client2 goes to the same gateway, GLBP gives secong MAC address. That's how it provides "load balancing". If you have a single client (for example, firewall), it will ask for MAC address once (through ARP), and then will use it all the time until ARP entry expires. Here is a link to Cisco, explaining how it works.
Hi Mike
Please can you provide your email address so that some of us can contact you, mine is snipped-for-privacy@gmail.com.
I have some few questions to post.
Thank You,
Phoneswww.ciscoheadsetadapter.comwww.headsetadapter.com
