General Router Question
Jul 27, 2005 1 Replies
Hi Everyone,
Currently I'm working on the Secur IOS course for CCSP and was thinking of picking up a used router - possibly 2 - from ebay. What's the minimum router I should be looking at that would encompass the IOS FW and the VPN functionality?
Thanks, BWG
B. Gray schrieb:
Even with a Soho91 you can setup FW and VPN. It isn't a well perfoming VPN server, but it works same as on the larger routers and IOS is cheap. If you wan't more features the next step is a
83x with Plus image.
-- Uli
