FWSM - Problem listing interfaces using SNMP and Solarwinds Performance Monitor
Nov 16, 2006 2 Replies
FWSM - Problem listing interfaces using SNMP and Solarwinds Performance Monitor open original image
Greetings
This might be something for Solarwinds to handle but I thought I just check with this forum for any additional input. We are using Solarwinds Network Performance Monitor to analyze and monitor our network. Solarwinds uses SNMP to gather statistics and check for availability on the nodes configured in Solarwinds. Our FWSM modules has been listed ok for some time now but lately I've been adding interfaces to the module as our network is expanding and none of these new interfaces are shown when using Solarwinds to index the FWSM. As I said, this might be a problem for Solarwinds but is there any SNMPconfiguration I could have messed up to block SNMPservers from seeing the new interfaces? All the new interfaces are operational and working properly.
Regards Fredrik Hofgren
Fredrik,
Should you need it, SolarWinds has a User Forum too:
Sincerely,
Brad Reese Cisco Technical Forums
Already on it :) Thanks Brad
skrev:
