PIX 501 not receiving DHCP on external interface (default config)
Nov 16, 2006 6 Replies
Jump to replies (6)
I'm having problems with configuring a PIX to pick up a dhcp ip address on its external interface, and allow pings from the PIX to
the external world.
I have just reset the PIX and set back to factory defaults: write erase Reload configure factory-default write mem
(1) Its not picking up dhcp IP from my adsl router: pixfirewall# show ip address outside dhcp Temp IP addr: 0.0.0.0 for peer on Interface: outside Temp sub net mask: 0.0.0.0 DHCP Lease server: 0.0.0.0, state: 1 Selecting DHCP transaction id: 0x1B8898 Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs Next timer fires after: 1 seconds Retry count: 1 Client-ID: cisco-0016.c7f9.c402-outside
Is there a way to reattempt to receive a dhcp address?
(2) Also. If I set a static external IP address, the PIX501 cannot ping my ADSL router. pixfirewall# ping 192.168.1.254 192.168.1.254 NO response received -- 1000ms 192.168.1.254 NO response received -- 1000ms 192.168.1.254 NO response received -- 1000ms
Thanks Nick
PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 hostname pixfirewall names pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside dhcp setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80
Can you post the result of a
sh interface
You may have cabling problems. Do you have a cross-over cable between your PIX and router ?
What is your static external IP? Is 192.168.1.254 is ADSl Router IP?
CK
Use the PIX capture command to see if the PIX is transmitting DHCP requests and to see if it is receiving DHCP response.
Depending on twhat you see or do not see in the capture traces, you should have an idea where to look next
I replaced the external cable, and suddenly I received a dhcp address, and could ping the router and the outside world.
Thank you all for your ideas. Nick
COOL
snipped-for-privacy@gmail.com wrote:
