Flush-mount 2970?
May 23, 2006 0 Replies
I have a small problem with some 2970s and horizontal wire managers. The way the mounting tabs install onto the switches, the face of the switch stands out about .75" But the wire managers mount flush. The result is my neatly-run cables come out of the manager and kink over at an extreme angle to plug into the switch.
Is there a different set of brackets I can get for the switches so that their faces will sit flush with the vertical rack rails? Or some kind of spacer or standoff I can use for the wire managers to get them to sit flush with the switches?
