Floating Virtual IP
Jul 14, 2007 5 Replies
Hello,
Does anyone know if this setup is possible and if so, which router or device can do this.
Virtual floating IP.
Site A: Server 1 Site B: Server 2
1 IP pointing to A site.
Scenario: If site A's server doesnt answer send the traffic to site B and the router there will forward it to the site B server.
There is a VPN tunnel connecting sites A & B.
The server on site A and B are exactly the same. So if for some reason site A server fails the router should send the traffic then to site B.
Yes I know there are redundancy applications that can do this and thats what they are for, but is this possible from a router perspective?
Correct me if I'm wrong, but would the return traffic here be the issue? COnsidering that traffic would come from a different IP all together or is this where PAT comes in?
Hope i clearly explained what I'm trying to do here; any recommendations are appreciated.
GNY
In the Cisco world you would use a Content Services Switch (CSS 11000 series) or IOS Server Load Balancing (SLB) for this however both of these solutions are expensive. CSS's start at around $11,000 and SLB is only supported on the 3640 & 3660 (both end of life), highend router platforms (7100, 7200, 7300, 7400 & 7600) and the 6000 / 6500 switches.
There are many other maufacturer's who offer similar devices and may be a cheaper alternative such as Radware, Alteon (Nortel), F5 and Foundry.
Jmes
James.. Thanks for the reply.. So such a setup is not possible out the box with any device.
What about multi-homed BGP? There a possiblity with that?
Thanks!
GNY
Sorry I meant.. with any device except for those you mentioned.
What exactly would this setup be called?
GNY
Maybe you could do something clever with a routing protocol - BGP, OSPF or RIP software running on the server might be able to provide this funtionallity but I have never heard of anyone doing this.
This funtionality is available in any Server Load Balancing appliance or software, so I would call it Server Load Balancing :-)
There is probably an Open Source / Linux solution out there that would work?
James
Thanks James. I'll look into it.
GNY
