Excessive interface resets on Cisco 1841 and FIOS line
Feb 06, 2008 1 Replies
Hello everyone,
I have a Cisco 1841 that is hooked up to a FIOS line. I am getting a huge amount of interface resets on the WAN interface, cannot figure out why. Any ideas would be highly appreciated. The sh run and sh int are below.
Thanks, Arthur.
Router#sh run Building configuration...
Current configuration : 4179 bytes ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname Router ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 logging console critical enable secret 5 ! aaa new-model ! ! aaa authentication login local_authen local aaa authorization exec local_author local ! ! aaa session-id common memory-size iomem 5 no ip source-route ip cef ! ! ! ! no ip bootp server multilink bundle-name authenticated ! crypto pki trustpoint TP-self-signed-1875086813 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-1875086813 revocation-check none rsakeypair TP-self-signed-1875086813 ! ! crypto pki certificate chain TP-self-signed-1875086813 certificate self-signed 01 3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101
04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D
43657274 69666963 6174652D 31383735 30383638 3133301E 170D3038 30313235
30333035 31315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504
03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31
38373530 38363831 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030
81890281 81009D3B 9DB65BBE DB1FC4BF 40C33D28 F887F1F1 044CDE60 2278E968
210DA767 59FAD375 07E94C10 941AAF01 FCCD51AA 98D85AD5 9118DA17 0EA616EF E4867A3A 71E75D13 0AB628B7 18ABADF5 A7B6182C 89A51BD9 4B4A92DB 2C0771F9
5C362A16 E6093A3E 38A40EBB FC6C7F77 47B51851 1DB62240 3E61B352 701C6F94
7793F829 10C50203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF
30110603 551D1104 0A300882 06526F75 74657230 1F060355 1D230418 30168014
49C0AEAD BB0FBACB 7DE8391E B011D322 4B5E0C30 301D0603 551D0E04 16041449 C0AEADBB 0FBACB7D E8391EB0 11D3224B 5E0C3030 0D06092A 864886F7 0D010104
05000381 81008D87 34D17DE1 7D30C941 FA521365 8EB5A043 F6C211D8 91C70641
9F94C4CB 9759FF0F DF0CA56E 872FB1EF 271010BC E0FE6EEC F52CDB8E 35EB896F
266F2644 D0CAE6FB 4044B085 AD6DCE1B C06645B7 1436DE52 FD30303B 78570CCC
8A2BFB24 DC4E933E 763BD91F B7C44089 2F47B568 CB34D267 BE39B10E 659EE703
69A02045 C7C4 quit ! !
archive log config hidekeys ! ! ip tcp synwait-time 10 ! ! ! interface Null0 no ip unreachables ! interface FastEthernet0/0 description $FW_OUTSIDE$ ip address dhcp client-id FastEthernet0/0 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable no mop enabled ! interface FastEthernet0/1 description $FW_INSIDE$ ip address 192.168.1.10 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip nat inside ip virtual-reassembly ip route-cache flow speed 100 full-duplex no cdp enable no mop enabled ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 dhcp ! ! ip http server ip http access-class 4 ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet0/0 overload ! logging trap debugging access-list 1 permit 192.168.1.0 0.0.0.255 access-list 2 permit 192.168.1.33 access-list 4 remark HTTP Access-class list access-list 4 remark SDM_ACL Category=1 access-list 4 permit 192.168.1.0 0.0.0.255 access-list 4 deny any no cdp run ! ! control-plane ! banner login ^CLog Off!^C ! line con 0 login authentication local_authen transport output telnet line aux 0 login authentication local_authen transport output telnet line vty 0 4 access-class 2 in privilege level 15 authorization exec local_author login authentication local_authen transport input telnet ssh ! scheduler allocate 20000 1000 end
Router#sh int FastEthernet0/0 is up, line protocol is up Hardware is Gt96k FE Description: $FW_OUTSIDE$ Internet address is REMOVED MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 10/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:05, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 4099000 bits/sec, 568 packets/sec 5 minute output rate 178000 bits/sec, 306 packets/sec 618093632 packets input, 1102765327 bytes Received 3 broadcasts, 4 runts, 0 giants, 0 throttles 501 input errors, 501 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 314677217 packets output, 1892616249 bytes, 0 underruns 0 output errors, 0 collisions, 2566 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet0/1 is up, line protocol is up Hardware is Gt96k FE Description: $FW_INSIDE$ Internet address is 192.168.1.10/24 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 10/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 2/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 188000 bits/sec, 306 packets/sec 5 minute output rate 4097000 bits/sec, 569 packets/sec 314856276 packets input, 3309471917 bytes Received 298452 broadcasts, 137514 runts, 0 giants, 0 throttles 435829 input errors, 435829 CRC, 280 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 618176271 packets output, 837991282 bytes, 0 underruns 0 output errors, 0 collisions, 5 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out NVI0 is up, line protocol is up Hardware is NVI Interface is unnumbered. Using address of NVI0 (0.0.0.0) MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation UNKNOWN, loopback not set Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out Router#
My first suggestion would be to check to physical connections. I would replace cat5 cable. I'm not sure what FIOS uses at the DeMarc, but you could check out that hardware as well.
