I am aware of the fact that 7600 does not support Color Aware Policers.
What is the behavior of the 7600 regarding Ethernet ingress frames with QinQ and DEI bit set recieved by an NNI port? Will the 7600 transport them in the color blind mode or will these frames will be discarded (as in case of the CFI on Ethernet UNI port)?
I can't find a proper documentation on cisco side. Can you also kindly refer to the relevant documentation?
Thanks Alex
