EIGRP on Lanlink interfaces
Dec 14, 2006 3 Replies
Jump to replies (3)
EIGRP on Lanlink interfaces open original image
Hello all
I am runnning two Cisco 2801 with IOS 12.3(8)T6. Both Routers are connected (fa0/0) to network 10.10.10.0 and 170.11.1.0 (fa0/1). HSRP and EIGRP are configured this way
Router A
interface FastEthernet0/0 ip address 10.10.10.3 255.255.255.0 speed 100 full-duplex standby 150 ip 10.10.10.5 standby 150 timers 1 3 standby 150 priority 110 standby 150 preempt standby 150 track FastEthernet0/1
interface FastEthernet0/1 ip address 170.11.1.253 255.255.255.0 standby 152 ip 170.11.1.1 standby 152 timers 1 3 standby 152 priority 110 standby 152 preempt standby 152 track FastEthernet0/0
router eigrp 150 redistribute static network 10.0.0.0 network 170.11.0.0 no auto-summary
ip route 0.0.0.0 0.0.0.0 10.10.10.1 ip route 172.19.70.0 255.255.255.0 170.11.1.4 ip route 172.25.11.0 255.255.255.0 170.11.1.4
Router B
interface FastEthernet0/0 ip address 10.10.10.4 255.255.255.0 speed 100 full-duplex standby 150 ip 10.10.10.5 standby 150 timers 1 3 standby 150 priority 105 standby 150 preempt standby 150 track FastEthernet0/1
interface FastEthernet0/1 ip address 170.11.1.254 255.255.255.0 standby 152 ip 170.11.1.1 standby 152 timers 1 3 standby 152 priority 105 standby 152 preempt standby 152 track FastEthernet0/0
Interfaces fa0/1 are connected to a switch via Lanlink on remote side, fa0/0 is connected to a switch on local side. If Lanlink on Router A fails interface fa0/1 stays up because connection to modem is still ok but remote network is not reachable any more via this interface. HSRP doesn't switch of course. I can't see any eigrp route "sh ip route eigrp". What can i do to fix this issue?
Thanks in advance.
Andre Wisniewski
i am not sure i understand your topology - are the 2801 on the same or different sites?
use "object tracking" to let HSRP switch based on access to an address or routing table contents.
maybe the 2 routers should be exchanging routes over the HSRP interface, so they should have a routed path between them - that will also "fix" some transitional forwarding black holes when the network topology changes.
personally i would use OSPF instead - at least you can predict what it will do :)
messagenews: snipped-for-privacy@79g2000cws.googlegroups.com...
They are on the same site.
contents.http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_featu...>
OK. I will have a look at it
It's worth thinking about it. Thanks so far.
contents.http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_featu... Very helpful answer. Thanks a lot. Here is my solution.
I added ...
track 100 rtr 1 reachability delay down 3 up 3
interface FastEthernet0/0 standby 150 track 100 decrement 50
ip sla 1 icmp-echo 170.11.1.23 request-data-size 512 timeout 1000 threshold 2 frequency 3
ip sla schedule 1 life forever start-time now
