problem with wireless lan
Nov 28, 2007 0 Replies
we have configured a vlan 602 to be used with a restricted ssid Employee
this particular portion of the config in user-distribution(UD) switch that connects to a dedicated wireless access switch was posing a problem .
interface Vlan602 description Udc-WA/10.8.205.0/255.255.255.0/602 ip address 10.8.205.5
255.255.255.0--------------------------------------------------------- problem ip helper-address 10.8.58.36 ip helper-address 10.8.53.25 no ip redirects no ip unreachables no ip proxy-arp ip pim sparse-mode load-interval 60 arp timeout 28800 standby 1 ip 10.8.205.1------------------------------problem standby 1 timers msec 500 2 standby 1 priority 200 standby 1 preempt delay minimum 60 standby 1 track GigabitEthernet1/1 40 standby 1 track GigabitEthernet1/2 40 ! any user trying to connect to wifi using ssid Employee(associated with vlan 602) was not getting any ip from DHCP server.
however when we did this it worked
interface Vlan602 description Udc-WA/10.8.205.0/255.255.255.0/602 ip address 10.8.205.1
255.255.255.0--------------------------------------------------------- made the ip address same as
-------------------------------------------------------------------------------------------------------------- default-gateway which was also
-------------------------------------------------------------------------------------------------------------- the standby ip ip helper-address 10.8.58.36 ip helper-address 10.8.53.25 no ip redirects no ip unreachables no ip proxy-arp ip pim sparse-mode load-interval 60 arp timeout 28800 ----------------------------------------------------------removed this line standby 1 timers msec 500 2 standby 1 priority 200 standby 1 preempt delay minimum 60 standby 1 track GigabitEthernet1/1 40 standby 1 track GigabitEthernet1/2 40 !
any solutions to this problem? we cannot keep the interface ip same as tht of th default gateway
