EIGRP: Default Route is not propagating
Jul 17, 2006 3 Replies
Jump to replies (3)
Hub and Spoke network.
3700 hubFrame Relay
Sites are all 1721 Stub mode
I have a route map in a router pointing to my default gateway. I see the route propogated to the 3700 using "Sh ip eigrp top 0.0.0.0
0.0.0.0, however it does not make it to the remote sites. All other routes are distributed to EIGRP.
Any ideas?
There are no acl's involved, and otherwise EIGRP is working normally.
3700 hubFrame Relay
Any ideas?
3700 hubFrame Relay
Any ideas?
  1. Does the 3700 install default into the RIB ( main routing table) from the EIGRP topo table?
  2. Which IOS version is running on 3700?
