DynDNS or not to DynDNS doubt
Nov 16, 2005 4 Replies
Jump to replies (4)
this is maybe a little bit off topic, but anyway, is your experience with DynDNS services positive or negative? I'm in doubt what to offer to one of my SMB customers since he uses dynamic public ip address that changes every
24 h, but he needs to access his work site from home with VPN. Is dynDNS enough reliable solution or should I consider obtaining static ip address (this will add to the cost) or even providing this VPN service trough my infrastructure with VRF-lite or DMVPN which will add to the deployment time and to the cost accordingly...
B.R. Igor
Hi Igor
I have positive experience with "no-ip.com" dynamic DNS service. It work fine for more than a yer with several instaltions
I suppose you are from Croatia
M.
Yes I'm from Croatia... Well, thanks for your valuable response...I just wanted to know how ddns is reliable service in real environments...
B.R.
I tried to use Dynu.com using the windows client and it almost *NEVER* automatically updated. Whenever my DSL changed address my ddns name stopped working till I manually changed it on their website. I've since switched to dyndns.org and it has been working reliably. dyndns.org is built into Linksys & Netgear routers (at models I've used).
DiGiTAL_ViNYL (no email)
I have been using them for years with no problem at all.
Tony
