Frame-Relay interface-dlci command with 'protocol ip'
Nov 16, 2005 0 Replies
According to CCO, there is an optional bit to the 'frame-relay interface-dlci ' command which goes:
protocol ip ip-address (Optional) Indicates the IP address of the main interface of a new router or access server onto which a router configuration file is to be automatically installed over a Frame Relay network. Use this option only when this device will act as the BOOTP server for automatic installation over Frame Relay.
Anyone know how you use this? It's not obvious how to make the server more a bootp server than it is by default as 'ip bootp-server' is a default command - it looks as though I need to switch this on somehow as the 'protocol ip' isn't an option under my frame relay default as I have it currently.
I'd very much appreciate the help on this!
cheers Danny
