DHCP with ASA5500's and IDS4215's
Oct 16, 2006 0 Replies
Does anyone know the pros and cons of moving from Static ip to DHCP when using the ASA 5500 security Appliance and the IDS4215 with full Trend Micro Anti-X.
I am trying to see if anything states that DHCP is not suitable for this enviroment, and static should be used to Vica-Versa.
As the ASA only logs IP addresses moving to DHCP seems to blow the audit trail unless you keep a history of the DHCP leases and ASA logs. Same applies to the Anti-X on the ASA?
Guidance/Advice/Documentation greatly appreciated. Gary
