Deny
Apr 26, 2005 2 Replies
How can I block all inbound connection attempts from a particular IP address?
In article , J1C wrote: :How can I block all inbound connection attempts from a particular IP :address?
What platform? Which software and which features?
On the PIX, you would put a deny ip host HOSTIP any in the access-list you are applying as your access-group against the outside interface. You would need to put the line above any 'permit' of 'any' that you had.
On IOS, you would normally create a numbered access list in the range 100-199, something like
access-list 101 deny ip host HOSTIP any ! put any other restrictions here ! then make sure you permit everything else you want as the default ! is to deny if you have anything in the active ACL access-list 101 permit ip any any
then you would go into interface configuration mode for the outside interface and apply it:
interface FastEthernet0 ip access-group 101 in
