command authorization with radius ?
Dec 02, 2005 2 Replies
Vivek
Command authorization will work with tacacs+ only. We cannot have it with radius.
Hi all Recently i've tried to configure cisco 1751 with an exec command authorization on a radius server, namely freeradius. Unfortunately when i try to enter:
aaa authorization commands 15 default group rgroup none
the router is displaying:
%AAAA-4-SERVNOTACPLUS: The server-group "rgroup" is not a tacacs+ server group. Please define "rgroup" as a tacacs+ server group.
rgroup is defined as:
aaa group server radius rgroup server 10.1.1.1 auth-port 1812 acct-port 1813
Is it really not possible to use a radius server to do a command authorization ?
WM
I do not believe the RADIUS protocol supports command authorization, only TACACS.
