Cisco VPN 3000 Series connecting to a DLINK DI 804HV
Jan 13, 2007 5 Replies
Cisco VPN 3000 Series connecting to a DLINK DI 804HV open original image
Hi
has anyone any experience of setting up a VPN tunnel with between these two? I have managed to get the IKE side of things up but not the IPSEC, I am might confused.
Any help will be greatly appreicated.
Hi Ginger,
You may wish to investigate D-Link DI-804HV:
VPN Wizard
Sincerely,
Brad Reese
2007 Cisco Salary Rates
Hi Brad,
I did just that but it still get the IKE up but not the IPSEC side of things. The only thing I can think of is the mask of the local network on the 3000 is a 19 bit mask.
Ginger,
Configuring NAT Transparent Mode for IPSec on the VPN 3000 Concentrator:
Sincerely,
Brad Reese Cisco Networking Academy WAN Emulation Lab Kits
Hi Brad,
thanks for the reply, there is no natting at all, both devices have internet addresses, (Class C), but I see where you are coming from, the only problem is that I cannot change the port on the Dlink.
Hi Brad and all,
just a quick note to say thanks for all your help, and the problem was basically down to super subnetting on the DLink, sort that out and every thing is fine. For anyone that is interested the Linksys VPN cable routers work a treat as VPN routers but the DLINK has some nicer features like allowing only certain MAC's to use the tunnel etc which is nice in a home environment.
Thanks again
