CISCO SOHO91 Help Needed
Nov 08, 2006 3 Replies
Jump to replies (3)
CISCO SOHO91 Help Needed open original image
Greetings:
I recently obtained a used CISCO SOHO91 router which I would like to use on my home LAN but am having difficulty configuring the router, I have cabled my hardware (cable modem, router, workstation, and ip phone) according to the router documentation but I am unable to access the web interface although I am able to access the console.
I would like to know if there is a way to do a factory reset or reset that will allow me access to the web interface, if not what do I need to do to allow access to the web interface? Unfortunately I am not Cisco IOS literate enough as of yet to resolve this issue, I would appreciate any assistance you can offer.
I connect to the Internet via cable modem (DHCP) and would like to have both my Sun Blade 150 Workstation and my Grandstream BT-101 IP Phone assigned DHCP address by the CISCO SOHO91, at some point I may have another two workstations requiring DHCP addresses also.
Not sure if this will help or not?
Router>show version Cisco Internetwork Operating System Software IOS (tm) SOHO91 Software (SOHO91-K9OY6-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Synched to technology version 12.2(11.2u)T TAC Support:
(c) 1986-2002 by cisco Systems, Inc. Compiled Wed 30-Oct-02 21:39 by ealyon Image text-base: 0x800131D8, data-base: 0x80814E98
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1) ROM: SOHO91 Software (SOHO91-K9OY6-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 43 minutes System returned to ROM by reload System image file is "flash:soho91-k9oy6-mz.122-8.YN.bin"
CISCO SOHO91 (MPC857DSL) processor (revision 0x300) with 29492K/3276K bytes of memory. Processor board ID AMB07390JXY (3900719863), with hardware revision
0000 CPU rev number 7 Bridging software.
2 Ethernet/IEEE 802.3 interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Configuration register is 0x142
Router>show webflash
Web flash directory: File Length Name/status 1 986 ConfigExp.cfg 2 474217 CRWSbHlp.html 3 826887 CRWS_1.jar 4 343149 CRWS_2.jar 5 61492 CRWS_VPNLogin.jar 6 47026 GUI.html 7 4895 home.html 8 8082 loading.gif 9 3463 VPNLogin.html [1770788 bytes used, 64220 available, 1835008 total]
Thank you - dpyvbhyydhzl
SOHO91 password recovery procedure:
Greetings:
I was not locked out of the router web interface because of lack of password but rather that it was unreachable via the IP 10.0.0.1 I had assigned.
These are the commands that I entered from the console, I am not sure that they are correct as I am still not able to access the web interface and I can not reach hosts on the Internet:
Router>enable Router#write erase Router#reload
Router>enable Router#configure terminal
Router(config)#hostname Cisco Cisco(config)#enable secret p455w0rd Cisco(config)#ip subnet-zero Cisco(config)#no ip domain lookup Cisco(config)#ip dhcp pool DHCPpoolLAN_0 Cisco(dhcp-config)#network 10.0.0.0 255.0.0.0 Cisco(dhcp-config)#default-router 10.0.0.1 Cisco(dhcp-config)#exit
Cisco(config)#interface ethernet0 Cisco(config-if)#description LAN Interface Cisco(config-if)#ip address 10.0.0.1 255.0.0.0 Cisco(config-if)#no shutdown Cisco(config-if)#ip nat inside Cisco(config-if)#exit
Cisco(config)#interface ethernet1 Cisco(config-if)#description WAN Interface Cisco(config-if)#ip address dhcp Cisco(config-if)#no shutdown Cisco(config-if)#ip nat outside Cisco(config-if)#exit
Cisco(config)#ip nat inside source list 1 int eth0 overload Cisco(config)#access-list 1 permit 10.0.0.0 0.255.255.255 Cisco(config)#exit
Cisco#copy run start
Any assistance is greatly appreciated.
I notice that you do not have an "ip routing" command.
You appear to be translating hosts with source address 10/8 into the IP address of internetface ethernet0 -- i.e., 10.0.0.1 . Try eth1 instead of eth0 there.
