Cisco 500-24 switch alerting on half duplex?
Nov 16, 2005 2 Replies
John Smith
either set both to AUTO or hard code both. dont just hard code one and not the other.
I have a Cisco 500-24 switch. Port 2 is set forced to 10/half. A Cisco router plugs into this link, which has a 10/half ethernet connection (doesn't support full.)
Why does the switch keep throwing up the alert light? Log shows this;
Port Fa2: Detected a half duplex configuration or a duplex mismatch on this link.
Is there a way to disable this?
Yes, that's what I said. A device which only supports 10/half is by default hardcoded to 10/half. There is no configuration on the router for duplex or speed. (Yes, it is an old router.)
Any idea why the switch is alerting?
