PIX configuration -- 3 way handshake incomplete
Jul 28, 2009 2 Replies
I'm trying to configure my outside device to authenticate to my internal TACACS server. The outside device will need to go through my firewall to reach the TACACS server. PIX is using static and conduit configurations.
After a capture, it looks like the SYN-ACK from the TACACS server back to the outside device is not getting through. reference below Inside capture packet does not show in Outside capture.
10.67.153.54.49 > 192.168.22.129.23532: S [tcp sum ok]
207178040:207178040(0) ack 1004279043 win 16384 (ttl 121, id 16628)
The static and conduit statements I have in my configuration: static (inside,outside) 10.67.153.54 10.67.153.54 netmask
255.255.255.255 0 0 conduit permit tcp host 10.67.153.54 eq tacacs host 57.69.22.129
Looking for help in understanding what I am missing from my configuration to allow the 3-way handshake to complete.
Thanks. Jeff
outside device : 192.168.22.129 inside tacacs server : 10.67.153.54
I did a capture on the outside and inside PIX interfaces.
From OUTSIDE interface:
9 packets captured
192.168.22.129.23532 > 10.67.153.54.49: S [tcp sum ok]
1004279042:1004279042(0) win 4096 (ttl 255, id 10770)
10.67.153.54.49 > 192.168.22.129.23532: . [tcp sum ok]
3032334760:3032334760(0) ack 1005633663 win 0 (ttl 121, id 1)
192.168.22.129.23532 > 10.67.153.54.49: R [tcp sum ok]
1005633663:1005633663(0) win 4096 (ttl 255, id 10772)
192.168.22.129.23533 > 10.67.153.54.49: S [tcp sum ok]
1286061587:1286061587(0) win 4096 (ttl 255, id 10840)
10.67.153.54.49 > 192.168.22.129.23533: . [tcp sum ok]
2425551338:2425551338(0) ack 1287592320 win 0 (ttl 121, id 1)
192.168.22.129.23533 > 10.67.153.54.49: R [tcp sum ok]
1287592320:1287592320(0) win 4096 (ttl 255, id 10841)
192.168.22.129.23534 > 10.67.153.54.49: S [tcp sum ok]
352839760:352839760(0) win 4096 (ttl 255, id 10939)
10.67.153.54.49 > 192.168.22.129.23534: . [tcp sum ok]
1346473921:1346473921(0) ack 354529447 win 0 (ttl 121, id 1)
192.168.22.129.23534 > 10.67.153.54.49: R [tcp sum ok]
354529447:354529447(0) win 4096 (ttl 255, id 10941)
9 packets shown
From INSIDE interface:
17 packets captured
2835789200:2835789200(0) ack 1005633663 win 0 (ttl 121, id 1)
207178040:207178040(0) ack 1004279043 win 16384 (ttl 121, id 16631)
1004279043:1004279043(0) ack 207178041 win 16384 (ttl 121, id 16631)
2049736084:2049736084(0) ack 1287592320 win 0 (ttl 121, id 1)
10.67.153.54.49 > 192.168.22.129.23533: S [tcp sum ok]
444038263:444038263(0) ack 1286061588 win 16384 (ttl 121, id 16633)
1286061588:1286061588(0) ack 444038264 win 16384 (ttl 121, id 16633)
205011690:205011690(0) ack 354529447 win 0 (ttl 121, id 1)
10.67.153.54.49 > 192.168.22.129.23534: S [tcp sum ok]
1216721629:1216721629(0) ack 352839761 win 16384 (ttl 121, id 16642)
1216721629:1216721629(0) ack 352839761 win 16384 (ttl 121, id 16646)
352839761:352839761(0) ack 1216721630 win 16384 (ttl 121, id 16646)
17 packets shown
This looks like 3 way handshake does not complete; Outside device is sending a reset per below?
192.168.22.129.23532 > 10.67.153.54.49: R [tcp sum ok] 1005633663:1005633663(0) win 4096 (ttl 255, id 10772)
Does your Tacacs Shared secret match on the outside device and the TACACS server?
Be aware that conduit command has been replaced by access-list command, assuming your current PIX code version supports access-list commands. There have been security vulnerabilities related to the use of conduit commands.
You are correct that the three way handshake does not complete. You are correct that the outside device is sending the reset. The reason is that the outside device does not receive the SYN-ACK from the tacacs server.
I know that conduit statements has been replaced by access lists for quite some time. But as a contractor, I have to work with what I'm given and make the best of it.
Going back to my issue, I believe I have all the statements in place. It would be a route statement and a conduit statement. I'm pretty sure it's something trivial.
thanks anyway.
