changing speed of fiber modules on switches possible ?
Jan 21, 2008 2 Replies
i have a 3560G with 1Gbit Fiber Ethernet SPFs (GLC-SX-MM) and some older 2912MF-XL (with 12 100Mbit Fiber modules).
I simply can not get a connect between these switches. Sure there is
1000BASE-SX on one side and 100BASE-SX on the other side, but i thought the 1GB-module would do autosensing. As far as i can see it is not possible to change the speed of the
1Gbit-SPF to 100 Mbit.
Is there no way to connect a newer Gigabit-switch with an older
100Mbit-Switch via the fiber ports? Is changing the speed of an interface only possible on copper- interfaces ?
I hope someone can explain this to me. Thanks ...
regards J.Hartmann
They are fixed speed 1000. They do not auto-negotiate.
No, fiber modules in general are not auto-speed sensing. You have to change out the optics to match what you are doing for anything.
You really need a 100-Base-FX SFP for your Gigabit switch to hook them up and have it talk 100-Base-FX back to your old 2912MF-XL fiber module.
Cisco part #GLC-GE-100FX=, list price $250.
That part should work in a 3560G, you probably will want to double check that first on the data sheet for it.
