Cajun Avaya P580 crashes
Nov 06, 2006 3 Replies
Jump to replies (3)
I've been having a problem with a Cajun Avaya P580 locking up. I've swapped out the chassis, management engine, and all blades. So essentially I've installed a new switch however, at random times the switch will simply lock up.
I'm wondering if anyone here has run into the same problem.
Javier
hmmm..this is Cisco related?
They had a TON of issues with the 550 and the backplane. There was a manufacturing defect with the soldering process, this is going back a few years ago. Only issue I know of with them.
Hey,
Not really a Cisco problem , but how many Cajun Avaya newsgroups ar there? :) Thanks for the tip > > I've been having a problem with a Cajun Avaya P580 locking up. I've
Hi Javier,
You may also wish to investigate the Lucent Networking Forum for Cajun advice:
Sincerely,
Brad Reese Cisco Technical Forums
