Hi
I have problem with this. I need have bridge between s1/0.7 and FE2/1 in cisco and lan and wan port in intel. I choose lan and wan interface and mark Wan bridging. In cisco i receive packet only from cisco Fe2/1. I try with bridge ieee and dec. On the rest of subinterface in cisco i must have ip routing so i cannot use command: " no ip routing". Yesterday, when i connect two cisco routers with ours help, it does works but today between intel and cisco didn't works
thx for help or clue best regards popo
In cisco i have:
interface Serial1/0 description 41216084 no ip address no ip proxy-arp encapsulation frame-relay IETF no ip route-cache cef no ip route-cache no ip mroute-cache load-interval 30 frame-relay lmi-type ansi bridge-group 1
! interface Serial1/0.7 point-to-point description Warszawa ILMET no ip route-cache no ip mroute-cache no cdp enable frame-relay interface-dlci 102 bridge-group 1 ! interface FastEthernet2/1 no ip address no ip route-cache cef no ip route-cache no ip mroute-cache duplex auto speed auto arp timeout 120 no cdp enable bridge-group 1 !
bridge 1 protocol dec
sh bridge verbose
Total of 300 station blocks, 299 free Codes: P - permanent, S - self
BG Hash Address Action Interface VC Age RX count TX count 1 2D/0 00d0.9680.3518 forward FastEthernet2/1 - 0 3
0 1 4D/0 0011.8521.e4a9 forward FastEthernet2/1 - 0 1
0 1 AE/0 0004.75d5.5ef0 forward FastEthernet2/1 - 0 1
0 1 D4/0 0001.02df.26f2 forward FastEthernet2/1 - 0 3
0
Flood ports (BG 1) RX count TX count Serial1/0 0 0 Serial1/0.7 0 0 FastEthernet2/1 0 0
