BOSON CCNA NetSim ?
Dec 06, 2005 1 Replies
nookie211
Make sure that the interfaces are not shut down. Issue the no shutdown command at each interface. What is the output of show interfaces? Are you connecting to the two computers with a switch?
I've just bought this stuff and I'm not sure if this software works properly. I don't work in IT right now so I can't check any commands and settings on real devices, I just want to prepare myself for CCNA exam. I've got 2 PC:
1PC IP: 192.168.1.11 255.255.255.0 default-gateway: 192.16.1.1
2PC IP: 192.168.2.22 255.255.255.0 default-gateway: 192.16.2.1
I issued command on the router: int e0 ip address 192.168.1.1 255.255.255.0 no shutdown int e1 ip address 192.168.2.1 255.255.255.0 no shutdown router rip version 2 network 192.168.0.0
( if I add these lines aswell nothing is changed network 192.168.1.0 network 192.168.2.0 )
After that: from router: ping 192.168.1.1 succes ping 192.168.1.11 succes ping 192.168.2.1 succes ping 192.168.2.22 succes extended ping from 192.168.1.11 to 192.168.2.22 doesn't work
from PC1 ping 192.168.2.1 succes ping 192.168.2.22 unsucces from PC2 ping 192.168.1.1 succes ping 192.168.1.11 unsucced
I don't know why is that? I think it should be working but maybe I need to do something else.
mih00 wrote:
