ASA 5505: Multiple NAT statements for specific IP addresses
Oct 19, 2008 1 Replies
I have the need to present a machine on the outside interface on a specific IP address like this:
static (inside,outside) xx.xx.xx.211 192.168.1.10 netmask
255.255.255.240
So that 192.168.1.10 is on the outside on xx.xx.xx.211.
However, I also wish to present the DNS port on the inside (5353) on the outside on port 53. If I add this rule underneath my previous rule:
static (inside,outside) xx.xx.xx.211 53 192.168.1.10 5353 netmask
255.255.255.240
Will this work, or will the rule above it take over so that port 53 on the outside will map to port 53 on the inside? If so, what is the best approach, to put the second rule first, or to map port 5353 on
192.168.1.10 to a different external IP address?
Thanks. Andrew.
i am not sure about port static first or IP static, but you must use netmask
255.255.255.255 and UDP or TCP statements in your port statement. Give it a try ...
