Am I being thick?
Dec 19, 2006 2 Replies
Bod43
This is one of the cornerstones of IP routing. More specific routes are /always/ preferred over less specific ones. 10.2.0.0 255.255.0.0 null0 is less specific than 10.2.0.0 /20 If there are equally specific then the administrative distance is used to determine which one goes…
Guys
I'd appreciate a bit of help please
I have a large network, all cisco, all EIGRP, no reason or need to change
I have 2 core sites both running in a hub and spoke and both connected together
On all the spoke sites or satellite sites I want to stop traffic going to the other satellite and opposing core sites
I have a 20 bit network (FWIW)
One satellite site has an IP range 10.6.95.0/20
I want to stop all traffic getting to any
10.2.0.0 /20
10.3.0.0 /20
10.4.0.0 /20
10.5.0.0 /20
I created a set of access lists and applied them onto the S0/0 interface of the router, a basic deny anything to the above nets and it works
I want to move away from ACLs to route statements on some satellite centres, why?, cus I want to. Well it is my network
So on my 10.6.95.0 network I:
o Log onto a local server and start a ping to an IP address on a 10.2.0.0 network o Create a default route to route all traffic to S0/0 o Create a route for 10.2.0.0 255.255.0.0 null0 o Remove the EIGRP network o Watch the pings continue
Why does my traffic continue to get thru ?
In anticipation
--------- We don't stop playing because we get old We get old because we stop playing
10.2.0.0 /20
If there are equally specific then the administrative distance is used to determine which one goes in the routing table.
The order then is:
- Prefix length - Within a routing protocol - cost - Between Routing protocols - admin dist.
I noticed just too late that I had not answered your question.
"Am I being thick?"
Yes:-)
