Aironet Client Utility 802.1X+PEAP.
Aug 30, 2006 1 Replies
Aironet Client Utility 802.1X+PEAP. open original image
Hi Guys,
I've installed the release 6.6. I need to use 802.1X with a certificate (generated by ACS) plus PEAP. But the software (the most updated) doesn't permit me to use 802.1X and PEAP together. I need to use Windows to do that. Do you whether there is another Cisco Software that allow you to do that?
Thanks,
Alex.
Alex,
ACU does not include an MS-PEAP supplicant, so if you want to use MS-PEAP with a 350 card, you'll have to use another supplicant.
Windows Zero Config provides one such supplicant. The Cisco Secure Services Client (formerly Meetinghouse Aegis) is another such.
Regards,
Aaron
