ACU 6.6 and WPA-PSK not possible ?
Dec 03, 2005 2 Replies
Most relevant reply
Aaron Leonard
The 350 ACU does not include a WPA-PSK supplicant. If you want to do WPA-PSK with the 350, you'll need to use some other supplicant - for example, if your OS is XP SP2, then configure WPA-PSK in WZC. your OS is Windows 2000, which does not include a WPA-PSK supplicant, then you…
ACU 6.6 and WPA-PSK not possible ? open original image
Hello, I just had an Aironet 350 pcmcia, loaded latest firmware, latest ACU (6.6.00) and other utilities. Problem is I cannot understand how to configure WPA-PSK. In security section building a profile I just cannot find the place where definition has to take place and field for inserting the passphrase...someone can help or send me a tech note/screenshot/anything ? Please help, thank you very much and have a nice day. Ciao ! Mpeg
If your OS is Windows 2000, which does not include a WPA-PSK supplicant, then you will need to run a third-party supplicant.
Aaron
Thanks, got it done in WZC smooth ! Tnx, ciao Mpeg
