ACS and Oracle 9i on same machine?
May 20, 2005 1 Replies
Erik Tamminga
Hi, Combining different apps on the same server is possible. (Most of the times, unless both applications require different versions of different (incompatible) components). But the question is; will both applications work as expected? For ex. if someone runs a sql query on…
Hi all,
Does anyone use CiscoSecure ACS for Windows on Windows 2003 with Oracle
9i on the same machine?
Is it possible?
Any hints or config tips would be gratefully received.
Rgds,
Ken
Combining different apps on the same server is possible. (Most of the times, unless both applications require different versions of different (incompatible) components). But the question is; will both applications work as expected? For ex. if someone runs a sql query on oracle that consumes large amounts of resources (memory, cpu, disk i/o), ACS might be unable to service requests from the network. The other way around is the same; huge amounts of ACS traffic might render oracle out-of-service. So if both applications are idle most of the time then the answer is "Yes", otherwise, "maybe".
Erik
