4006 Sup Eng III as a Default Gateway?
Feb 07, 2006 1 Replies
Merv
Usually routed ports are used to connect to other network devices such as routers and L3 switches. Usually PCs would be connected to ports that are part of a VLAN. Of course there is no reason why you could not connect a PC to a routed port on your switch.
Hello,
I need to use a 4006 switch as my default gateway and would like your advice on what would be a better practice:
  1. Use the IP that is already on VLAN1:
int vlan1 ip address x.x.x.x x.x.x.x
  1. Configure one of the interfaces as Physical Layer 3, put IP on it, and use it as a DG.
int fa3/35 no switchport ip address x.x.x.x x.x.x.x
If #2 would be the better choice, which interface would normally be the one to pick for that purpose? Example: fa1/13 is connected to the inside port of my PIX and traffic goes out to the internet from there. Is fa1/13 the one i need..?
At the moment my PC is the only one pointing to the 4006 as a DG, using its vlan1 IP and it is working fine...
Thank you, Todd
