C3750 Layer 3 Switching and VLANs
Feb 07, 2006 8 Replies
Jump to replies (8)
Hi There,
I have the task of installing a new C3750 switch into an existing ip network. The existing network is just running a basic layer2 switching setup with daisy chained switches. They have a HP core switch that will do vlan tagging but will not actually separate networks into VLANs if that makes sense. I am tasked with installing a new L3 C3750 and providing 3 separate VLANs (all with the same IP network (but different masks) - otherwise it means readdressing everything!) and I need to filter traffic out between the VLANs. Has anyone got any example configs on how I can configure these VLANs and the router inside the Switch? Any ACL filtering examples would be greatly appreciated! I am new to VLANS and especially L3 Switches :-/
Thanks
Ryan
Hi Ryan,
Can you provide any current sceerion diagram to make the scenerio clear,
Untill now i only understood that you wantto install 3750 Switch as VLAN Tagging Server with restricted access.
Thanks, NETADMIN
Thanks for the super fast reply. I think I should take the HP and the VLAN tagging out of the loop first - so ignore the HP. I need to install a new C3750 L3 Switch.
I need to create 3 VLANs, 1x Terminal Servers (VLAN2) , 1x Clients/Workstations (VLAN3), 1x Management (VLAN4). I need to ensure that the Clients can only access the Terminal Servers on TCP3389 and I need to filter out ALL other traffic for getting to the servers. The C3750 will be L3. Can you provide a config example for this.
Also, I will need to enable portfast on the Server ports.
Sorry I am missing out the diagram as it's just a L3 Switch with 3 x VLANS and FIltering - my first post is confusing - so I've simplifed it a little.
... ! interface vlan3 ip address ... ip access-group from_clients in ! ip access-list extended from_clients permit tcp any any eq 3389 deny ip any any log !
Hi Lutz - thanks a million for the reply - I was looking into VACLs and all sorts - didn't think it was as easy as that! I am just wondering if you could also provide an example on configuring the L3 part of the switch?
Cheers
Ryan
ip default-gateway gateway IP ip classless ip route 0.0.0.0 0.0.0.0 gatewayIP
Thanks, NETADMIN
You will need to consult the usual configuration guides. They are very good.
Hi Lutz..
Is posted snipped-for-privacy@hotmail.com not by me
Thanks, NETADMIN
Try command in global config mode no ip routing and routing between vlans will be disabled
