4 T1 WIC for 3640?
Feb 02, 2006 5 Replies
jcottingim
There are dual Serial WIC's but not quad. They go for about $55 on eBay these days. So, if you already have an NM-2FE-2W with two open WIC slots, you only need two WIC-2T's (and supporting cables) J.Cottingim
I've ordered four new T1s from MCI for 6 Mbps Internet service. I plan to use an existing 3640 router. Is there a quad serial WIC card available?
If not, I guess I'll need an NM-4T. Can someone recommend an economical multi-port CSU/DSU for this application?
Thanks.
J.Cottingim
Do you already have CSU/DSUs? If no, you can get two VWIC-2MFT-T1 cards, which include the CSU/DSU.
6 refurbished units are in stock of the Cisco Part Number: VWIC-2MFT-T1
Sincerely,
Brad Reese BradReese.Com Cisco Engineers
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
All three of you guys recommended a two port WIC, which means I'd need two for my 4 T1s. I've only got two available slots in my router and thought that preserving a spare was pretty important. Am I making too big a deal out of this?
Yes.
But you can easily put in more WIC slots. You aren't limited to two WIC slots. External devices can go bad. Cabling can go bad. An integrated unit is better. Cisco doesn't make a 4-T1 integrated CSU/DSU card.
You were thiking of putting an NM-4T, so you must have a free NM slot. Another NM-2W or NM-2FE-2W can go in there if you need 2 more WIC slots later on.
