Any suggestions for an economical source of preterminated, armored/Interlok singlemode cable assemblies? 12 or 24 strand, SC or MTP connectors.
armored cable assemblies?
Jun 09, 2007
Nothing is all that economical in dealing with fiber. That type of thing is what I typically run. The place I've dealt with does it custom each time, nobody has a set length, connector, or anything they do consistantly which is the only way to drive down the costs if you can…
Nothing is all that economical in dealing with fiber. That type of thing is what I typically run. The place I've dealt with does it custom each time, nobody has a set length, connector, or anything they do consistantly which is the only way to drive down the costs if you can roll them out all the same.
But the place that Graybar got for me is reasonable, and the ends are a very nice UPC factory polish. Their place was cheaper than the other local cable assembly places that did it inhouse. Many times cheaper than calling in somebody with a fusion splicer. So, give your local wire distributer or a national like Graybar a call to see what they get for you.
