Keep having to reset Linksys router
Jul 15, 2004 5 Replies
Jump to replies (5)
Linksys Router: BEFSR41
On average, I lose my connection once per day. It's not the internet or my cable modem. I still have a connection, just my router "drops" it. I press the reset button on the router and then the connection is returned. I have upgraded to the latest firmware but still have the same problem. Does this sound like the router is dying?
"TC" wrote in news:UyuJc.27030$KP6.1184466 @twister.tampabay.rr.com:
I have the 1 port version of your router... and I noticed the newer firmware is quite unstable with the router.
I'm in the process of buying a new router... probably one from Zyxel which I heard are much more reliable.
I had the very same problem, only more frequently. I called Linksys tech support, and they had me go into the router setup and change two settings, and that solved the problem completely. I just can't remember what they were though. I think they were on the basic settings page. The tech said the settings were published on their web site.
DR
What firmware are you using?
NO
if the router was dead it wouldnt work. its a work or dont work box.
but theres a ton of settings inside the router, perhaps those need changing.
i suggest calling up RR and tell them your modem stays connected but your router gets disconnected, and give them your router model #. they should be able to help.
i use a dlink 704p router, which works fine on my dsl.
also newer firmware unfort does not always mean better.. :( ...
