how do I know if the cable modem is the source of my problems
Dec 25, 2004 17 Replies
Dave C.
Well unfortunately, you didn't say what type of cable modem. Some of them have a maintenance menu built in where you can see signal strength (up/down), S/N level, etc. If you post your specific model number and the up/down signal strength and noise levels, we can easier narrow…
I have had a wireless network for some time now. over the last couple of weeks, my online experiences have been slow. I use it for a week and all of asudden it is very slow. I surmised it might be my router. But when I took the router out of the equation, it didnt go as slow but there seeemed to be dropped connections. The inidicator in the system tray was indicating that it is "unavailable" and then would say it "is now connected". "Page not displayed errors" and other weird behavior such as getting to a page sometimes and for no reason, not getting to the same page. It seems to be the cable modem is the problem. I didnt think they can "go bad". Is there something I can do or diagnose if it is the cable modem? thanks for your help.
snipped-for-privacy@optonline.net
Well unfortunately, you didn't say what type of cable modem. Some of them have a maintenance menu built in where you can see signal strength (up/down), S/N level, etc. If you post your specific model number and the up/down signal strength and noise levels, we can easier narrow the problem down. -Dave
couple
behavior
What is cmts? also....this has been working great for years. Do you think there would all of a sudden be a problem with the cable line coming in? Yes i directly connected the modem to the computer viua ethernet. how do you explain the constant "disconnected" and "connected" messages i get in the systray. right now i connected it back thru the router and I am working normal. this is very perplexing. give it a little time and i might be having trouble any time soon. thanks
i can get to my config screen via 192.168.100.1. i have no idea of what any of this screen means. how do i send the stats here? print it out ? i can try to paste, but I dont know if it will come out ok. I will try to see if I can post the stats here. I can post the modem info. thanks
Modem 3Com Corp. External 2-Way Cable Modem Serial Number J0DH723F40 Boot Code Version 01.00.009a Main Image Version 1.12 Hardware Version 2.00 Cable Modem Static IP Address 192.168.100.1 Web Based Configuration Pages Version 604
thanks but the issue is not the wireless as I had the cable modem directly connected to the computer via ethernet.
Do you mean this still happens when you are connected directly to the cable modem via Ethernet? Dropped connections on a wireless network are often the result of radio interference. If this is what is happening, you should use NetStumbler to check your own network's signal strength and noise and to discover any other wireless networks using the same channel in your neighborhood.
Further questions about wireless networking should be posted to alt.internet.wireless.
Assuming you eliminated not just the router, but went to an Ethernet connection, the most likely source of your problem is somewhere in the RF part of the situation. That is, it's someplace between where the coax comes out the back of the modem, and where it gets to the CMTS. And to narrow it down even further, there's a slightly better chance that the problem is closer to your house than it is to the headend. The modem itself is very far down on the list of likely candidates.
OK, now somewhere in there should be signal levels and signal/noise ratio. While it's possible that your cable modem is bad, it's more possible that the signal TO the modem is bad. But you can use the cable modem to check that. Post the signal strength here. -Dave
Cable Modem Terminal System. It's essentially where the RF signal that's distributed to your neighborhood meets the fiber-optic part of the network.
Well, let's see. There are miles of cable, some exposed to the elements, some decomposing underground. Numerous connectors and splitters to come loose or corode, amplifiers to fail, and other miscellaneous stuff related to the distribution of the signal. Anywhere from a few hundred houses to a few thousand houses are passed, any one of which could connect something to the cable that could cause problems. New drops may be created as new customers sign-up. Old drops may be terminated incorrectly when customers drop their service.
Now let's compare that to your cablemodem. It's been sitting on your desk, gathering dust, and occasionally power-cycled. It's inside, so it's not exposed to any weather, and only people you've invited into your house have had access to it. Perhaps it's been jostled a few times as you've moved things around, but there's been no wind storms, no rain, no ground water, no freeze-thaw cycles, and it's probably not in direct sunlight.
Which part do you think is more prone to a problem after "working great for years"?
Sure, it *could* be the cablemodem, but the odds are very much against it. And without any troubleshooting, those odds are all we have to go on.
That actually would point towards a loose connector or bad Ehternet cable as the most likely cause.
Might you be using the same cable between the computer and the cablemodem as you were using between the cablemodem and the wireless router? Replacing that cable would be a prudent next step.
potatoes, etc) cubed
Make a crust from scratch - or go shamefully to the frozen food section of your favorite grocery and select 2 high quality pie crusts (you will need one for the top also). Boil the prepared delicacy until the meat starts to come off the bones. Remove, de-bone and cube; continue to reduce the broth. Brown the onions, peppers and celery. Add the meat then season, continue browning. De-glaze with sherry, add the reduced broth. Finally, put in the root vegetables and simmer for 15 minutes. Allow to cool slightly. Place the pie pan in 375 degree oven for a few minutes so bottom crust is not soggy, reduce oven to 325. Fill the pie with stew, place top crust and with a fork, seal the crusts together then poke holes in top. Return to oven and bake for 30 minutes, or until pie crust is golden brown.
Sudden Infant Death Soup
SIDS: delicious in winter, comparable to old fashioned Beef and Vegetable Soup. Its free, you can sell the crib, baby clothes, toys, stroller... and so easy to procure if such a lucky find is at hand (just pick him up from the crib and he?s good to go)!
SIDS victim, cleaned ½ cup cooking oil Carrots onions broccoli whole cabbage fresh green beans potato turnip celery tomato ½ stick butter
1 cup cooked pasta (macaroni, shells, etc.)
Remove as much meat as possible, cube
size of a baby?s fist (there should be one lying around for reference). Bake at 400°for about 25 minutes - or you could fry them in olive oil. Place the meatballs in the tomato gravy, and simmer for several hours. Serve on spaghetti. Accompany with green salad, garlic bread and red wine.
Newborn Parmesan
This classic Sicilian cuisine can easily be turned into Eggplant Parmesan If you are planning a vegetarian meal. Or you could just as well use veal - after all, you have to be careful - Sicilians are touchy about their young family members...
6 newborn or veal cutlets Tomato gravy (see index) 4 cups mozzarella, 1cup parmesan, 1cup romano Seasoned bread crumbs mixed with parmesan romano salt pepper oregano garlic powder chopped parsley Flour eggwash (eggs and milk) Peanut oil for frying.
Pound the cutlets. Dredge in flour, eggs, then the bread crumb mixture. Fry till golden brown in 350° peanut oil. In a baking pan, place a layer of gravy, then one of meat, gravy, and cheese. Another layer each of meat, gravy, and cheese. Then bake at 350° for 45 minutes. Serve on hot pasta with romano cheese.
Southern Fried Small-fry
Tastes like fried chicken, which works just as well. In fact you may want to practice cutting up whole chickens for frying before you go for the real thing. Whole chicken is much more efficient and inexpensive than buying pieces.
1 tiny human, cut into pieces 2 cups flour Onion, garlic Salt pepper garlic p
take longer than it actually does; as the entire house is filled with such a heavenly aroma, the waiting becomes almost unbearable.
1 whole child, cleaned and de-headed 1 batch cornbread stuffing (see index) ½ cup melted butter
Remove the giblets from the infant and set aside. Stuff the cavity where the child?s genitals and anus were located using ½ cup per pound of meat. Tie the arms flat to the body, then pull the skin flaps up to close the cavity. Now tie the thighs up tight to hold it all together. Place breast side up in a large metal roasting pan. Bake in 325° oven covered for 2 hours. Remove cover, stick a cooking thermometer deep into one of the baby?s buttocks and cook uncovered till thermometer reads 190°, about another hour.
Pro-Choice Po-Boy
Soft-shelled crabs serve just as well in this classic southern delicacy. The sandwich originated in New Orleans, where an abundance of abortion clinics thrive and hot French bread is always available.
2 cleaned fetuses, head on 2 eggs 1 tablespoon yellow mustard 1 cup seasoned flour
to form a glaze. Cut ribs into individual pieces and serve with extra sauce.
Fresh Sausage
If it becomes necessary to hide the fact that you are eating human babies, this is the perfect solution. But if you are still paranoid, you can substitute pork butt.
5 lb. lean chuck roast 3 lb. prime baby butt 2 tablespoons each: salt black, white and cayenne peppers celery salt garlic powder parsley flakes brown sugar 1 teaspoon sage 2 onions 6 cloves garlic bunch green onions, chopped
Cut the children?s butts and the beef roast into pieces that will fit in the grinder. Run the meat through using a 3/16 grinding plate. Add garlic, onions and seasoning then mix well. Add just enough water for a smooth consistency, then mix again. Form the sausage mixture into patties or stuff into natural casings.
Stillborn Stew
By definition, this meat cannot be had altogether fresh, but have the lifeless unfortunate available immediately after delivery, or use high quality beef or pork roasts (it is cheaper and better to cu
Remove as much meat as possible, cube, and brown in hot oil. Add a little water, season, then add the carcass. Simmer for half an hour keeping the stock thick. Remove the carcass and add the vegetables slowly to the stock, so that it remains boiling the whole time. Cover the pot and simmer till vegetables are tender (2 hours approximately). Continue seasoning to taste. Before serving, add butter and pasta, serve piping with hot bread and butter.
Offspring Rolls
Similar to Vietnamese style fried rolls, they have lots of meat (of course this can consist of chicken, beef, pork, or shrimp). Who can resist this classic appetizer; or light lunch served with a fresh salad? Versatility is probably this recipe?s greatest virtue, as one can use the best part of a prime, rare, yearling, or the morticians occasional horror: a small miracle stopped short by a drunk driver, or the innocent victim of a drive-by shooting...
2 cups finely chopped very young human flesh 1 cup shredded cabbage 1 cup bean sprouts 5 sprigs green onion, finely chopped 5 cloves minced garlic 4-6 ounces bamboo shoots Sherry chicken broth oil for deep frying (1 gallon) Salt pepper soy & teriyaki minced ginger, etc. 1 tablespoon cornstarch dissolved in a little cold water 1 egg beaten
Make the stuffing: Marinate the flesh in a mixture of soy and teriyaki sauces then stir fry in hot oil for till brown - about 1 minute, remove. Stir-fry the vegetables. Put the meat back into the wok and adjust the seasoning. De-glaze with sherry, cooking off the alcohol. Add broth (optional) cook a few more minutes. Add the cornstarch, cook a few minutes till thick,
Place seam down in a baking pan. Ladle tomato gravy on top, and bake at 325° for 30 - 45 minutes.
Umbilical Cordon Bleu
Nothing is so beautiful as the bond between mother and child, so why not consume it? Children or chicken breasts will work wonderfully also.
4 whole umbilical chords (or baby breasts, or chicken breasts) 4 thin slices of smoked ham, and Gruyere cheese Flour eggwash (milk and eggs) seasoned bread crumbs 1 onion minced salt pepper butter olive oil
Pound the breasts flat (parboil first if using umbilical cords so they won?t be tough). Place a slice of ham and cheese on each, along with some minced onion then fold in half, trimming neatly. Dredge in flour, eggwash, then seasoned breadcrumbs; allow to sit for a few minutes. Sauté in butter and olive oil until golden brown, about 6 minutes on each side.
Shish Kababes
As old as the hills, this technique has employed seafood, beef, pork, lamb, poultry, and vegetables; just about anything can be grilled, and young humans are no exception!
High quality marinade (Teriyaki and garlic perhaps)
1 inch cubes of tender meat, preferably from the nursery Onions bell peppers Wooden or metal skewers
Marinate the meat overnight. Get the grill good and hot while placing meat, vegetables, and fruit such as pineapples or cherries on the skewers. Don?t be afraid to use a variety of meats. Grill to medium rare, serve with garlic cous-cous and sautéed asparagus. Coffee and sherbet for desert then walnuts, cheese, and port. Cigars for the gentlemen (and ladies if they so desire)!
Crock-Pot Crack Baby
When the quivering, hopelessly addicted crack baby succumbs to death, get him immediately butchered and into the crock-pot, so that any remaining toxins will not be fatal. But don?t co
salt crab boil
Bring 3 gallons of water to a boil. Add sausage, salt, crab boil, lemons and garlic. Drop potatoes in, boil for 4 minutes. Corn is added next, boil an additional 11 minutes. Put the live babies into the boiling water and cover. Boil till meat comes off easily with a fork.
Oven-Baked Baby-Back Ribs
Beef ribs or pork ribs can be used in this recipe, and that is exactly what your dinner guests will assume! An excellent way to expose the uninitiated to this highly misunderstood yet succulent source of protein.
2 human baby rib racks 3 cups barbecue sauce or honey glaze (see index) Salt black pepper white pepper paprika
Remove the silverskin by loosening from the edges, then stripping off. Season generously, rubbing the mixture into the baby?s flesh. Place 1 quart water in a baking pan, the meat on a wire rack. Bake uncovered in 250° oven for 1½ hours. When browned, remove and glaze, return to oven and bake 20 minutes more to form a glaze. Cut ribs into individual pieces and serve with extra sauce.
Fresh Sausage
5 lb. lean chu
Stillborn Stew
By definition, this meat cannot be had altogether fresh, but have the lifeless unfortunate available immediately after delivery, or use high quality beef or pork roasts (it is cheaper and better to cut up a whole roast than to buy stew meat).
1 stillbirth, de-boned and cubed ¼ cup vegetable oil 2 large onions bell pepper celery garlic ½ cup red wine 3 Irish potatoes 2 large carrots
This is a simple classic stew that makes natural gravy, thus it does not have to be thickened. Brown the meat quickly in very hot oil, remove and set aside. Brown the onions, celery, pepper and garlic. De-glaze with wine, return meat to the pan and season well. Stew on low fire adding small amounts of water and seasoning as necessary. After at least half an hour, add the carrots and potatoes, and simmer till root vegetables break with a fork. Cook a fresh pot of long grained white rice.
Pre-mie Pot Pie
When working with prematurely delivered newborns (or chicken) use sherry; red wine with beef (buy steak or roast, do not pre-boil).
Pie crust (see index) Whole fresh pre-mie; eviscerated, head, hands and feet removed Onions, bell pepper, celery ½ cup wine Root vegetables of choice (turnips, carrots, potatoes, etc) cubed
