X10 & Ademco Noise?
Jan 08, 2007 0 Replies
I just had my Ademco Vista 20 panel installed... The turned it on and all my X10 stuff went nuts....
Luckily I had a spare filter and plugged the Transformer into that....
Is this NORMAL....
Eventually I am going to install the X10 transformer, but not until everything else is stable...
Why So noisy.... Would a ferrite on the Power leads help, or should I just stick with the X10 filter?
Bob
