PoerLinc Controller & X10 switches
Dec 09, 2005 0 Replies
Hi, guys,
I gave up on CM15a and bought a Smarthome PowerLinc Controller and I'm about to start writing macros on it.
However, for the switches, the software allows dimming only on the Smarthome ones.
Question is: May I tell the software I'm using a dimmable Smarthome switch and actually use one of my X10 ones? Does it work? If so, which one should I specify?
Thanks a bunch!
Flavio
