Hi, Everyone!
I've been using my Toshiba 1415-S173 with a 802.11b (Lucent Chipset) Mini PCI card for the past year and a half. Worked great, and the little on/off switch on the side worked perfectly for the wireless (light came on, turned off).
I put put a Intel 2200GB Mini PCI to replace the old card and get
802.11g capability, and the card works perfectly. However, the on/off switch on the Toshiba has no effect on the Mini PCI card.I put the old Lucent (Orinoco) chipset Mini PCI back in and it works fine with the switch.
Is there some way I could possibly get this switch working?
Thanks!
