On Sun, 24 Dec 2006 23:22:46 +0100, snipped-for-privacy@hotmail.com (Axel Hammerschmidt) wrote in :
A wireless access point _is_ a network bridge. That it also has a wireless radio is no more relevant than the wired ports in wired network bridges.
Again, a wireless access point _is_ a network bridge.
You are actually using it as a wireless Ethernet (client) bridge.
In other words, the F5D7330 _is_ "multi". ;)
Nope. A bridge like the F5D7330 does care about MAC addresses because that's how it knows whether to filter traffic or not. Failing to properly filter traffic would be a bridge abomination!
On Mon, 25 Dec 2006 15:44:40 +0100, snipped-for-privacy@hotmail.com (Axel Hammerschmidt) wrote in :
Nope. The only keeping track of stations is MAC bridging, and "buffering packets to help stations save power" isn't part of the access point definition. If you disagree, post an authoritative citation to back up your claims.
No, it's bridging.
In other words, it's a network bridge.
Indeed -- it's a wireless Ethernet (client) bridge.
That's a network bridge.
Filtering packets not addressed to a MAC at the other end.
Probaly becuase the Distribution system is assumed to be a wired network - certainly thats how Cisco use the term the DS connects the BSS's to form an ESS.
Though Cisco do some nice looking kit (1500's) that uses wifi to provide a meshed 's DS
That's wrong. An access point is not a bridge. An access points has a "bridging engine" - but that does not make it "a bridge".
Wrong, again.
Here, I am using the F5D7330 as a bridge/gaming adapter, the same way it is used with an Xbox or PSP. Not as a bridge.
No, as I wrote and you should have taken note of - if you could read - the computers got ip-addresses from the DHCP in the router.
There is no such thing as "multi". That term is non sence.
And you obviously don't know anything about the F5D7330.
Message-ID:
John Navas wrote:
: On Sun, 24 Dec 2006 17:43:44 -0800, Jeff Liebermann : wrote in : : : : > snipped-for-privacy@hotmail.com (Axel Hammerschmidt) hath wroth: : : >>The F5D7330 (802.11b/g) is one bridge/gaming adapter mentioned on : >>this link and I happen to be using one at the moment as an adapter : >>so I wanted to check up on whether it could handle more that one : >>computer - designated as "multi" (MAC addresses?) on the above link. : >>There's no mention of it being able to do so from the information on : >>the link. : >
: >John Navas didn't test all of the items mentioned. : : Correct. I based my assessment on information I deemed to be : reliable.
You base your mis-information on own assumptions, as your admission here confirms.
On Tue, 2 Jan 2007 22:53:01 +0100, snipped-for-privacy@hotmail.com (Axel Hammerschmidt) wrote in :
All of it. A wireless access point is simply a network bridge.
No such thing. (I suggest you come with a supporting citation _before_ making such a claim.)
Because the wireless access point is a network bridge. You seem to think it mindlessly repeats like a hub. It doesn't. Given station A wired to the wireless access point, and stations B and C connected wirelessly, traffic from B to A is _not_ repeated wirelessly to C. That's because a network bridge, in this case the wireless access point, filters traffic not addressed through a given port.
You're wrong.
According to the manufacturer, it's a "Wireless Ethernet Bridge." As I wrote.
I must have missed that. What real proof do you have?
On Wed, 3 Jan 2007 20:16:05 +0100, snipped-for-privacy@hotmail.com (Axel Hammerschmidt) wrote in :
Insults are a sure sign of a bankrupt position, and a sure way to end any sort of meaningful discussion. You are of course welcome to think whatever you want, no matter how silly. I'm not going to waste any more time on this.
