Specifically, I don't understand the difference between Netgear WGE111 (Gaming Adapter) vs NETGEAR's WG602 Wireless Access Point.
All I need is to connect to my WLAN using a given SSID/Channel in adhoc mode and connect my old Ethernet only PC.
Intenet - - - - - WLAN Router - - - - - ? __________Ethernet__________ PC
Can both do it?
appreciate detailed response on how I can do it if possible.
Thanks Gmu
