Yagi usless for wardriving
Sep 18, 2006 10 Replies
Jump to replies (10)
How about some remedial spelling courses?
" hath wroth:
Nope. Some clue as to the maker and model of your wireless card, what type of coax cable the 2m pigtail is made from, how you are measuring the signal, and what you are trying to accomplish, would be helpful.
Well, yeah, of course it's probably worse. Using an antenna with a tightly directional coverage area isn't ever going to be useful for trolling around looking for wifi. You'd be better off with an omni or a sector antenna. What made you think a yagi, especially one with that much gain, was going to ever be good for wardriving?
OK well you live and learn, I had thought it would be ok but obviously not. What about a parabolic type antenna is this better as it's more omni I guess
Wardiving I guess mostly. It's an Orinoco card and a 14db yagi. The pig tail is I guess some form of thin coaxial cable for the SHF freqs like 2.4 ghz
I guess with a pringle type antenna I would pull in a lot more ?
I made the below setup for war driving. I just put the USB adapter on the roof for general driving. I used the reflector when I wanted to check a weak or distant point.
" hath wroth:
Very thin, about 0.1" OD, coax cable is VERY lossy. The 0.250" OD is somewhat better. Orinoco comes in many flavors. I guess a card means PCMCIA or CardBus.
Do you really want to "pull in a lot more"? Let's say you've got a GPS plugged into your unspecified computer and are driving around with a directional high gain antenna. You'll probably pickup signals from about 500ft away or more. Your GPS will locate this distant station at your location, not theirs. Great way to make an inaccurate map.
Long range also implies narrow beamwidth. You have to point your antenna at the access point. Point it some other direction, and you don't hear it. Wanna drive down the road spinning the antenna round and round? Do you get the picture? Are you claiming that the yagi is less sensitive because it sees fewer stations? I'm not suprised unless you're spinning the yagi round and round as you drive.
What little wardriving I've done is with two simple antennas. I hang an 8dBi panel antenna out the right side passenger window with a coax cable to the laptop. Such a panel antenna has a beamwidth of about 60 degrees which eliminates any need to rotate the antenna. It's not overly sensitive so my GPS locations are fairly close. On the way to my palatial office, I pickup all the AP's on one side of the road. On the way back, I get the other side.
The other way is with a USB radio and the included 1/4 wave monopole antenna mounted on the roof. USB cable to the laptop. That eliminates and coax cable and it's RF losses. I haven't found a great way to secure the USB radio, so I just wrap it in foam roll packing material and cram it under my luggage carrier. Hopefully, you can do better.
It's RG316 with 3.6db loss per 100m or 1m not sure, brought from
as well as the 14db yagi
I mean PCMCIA but an OEM version with a BT logo on the sticker
I just want to see what I can get around my location, my PDA picked up over
40 networks just in my road. I was'nt planning to drive anywhere for now
Anyway I nave brought a pringle antenna off ebay just to see what happens !
" hath wroth:
Try again. RG-316 is 1.2dB/meter. 6dB of loss will cut your detection (and transmission) range in half. Do the math.
My guess is this one:
antenna doesn't look too horrible and should work.
That would be war walking, not war driving. Change your title.
Sigh. You must have money to burn.
Look carefully at the connect on the Orinoco something card you bought. They are easily mashed and destroyed.
Well the site states 3.6db ? Sorry getting a bit too complex
It works but too directional apparently not the antenna for any form of war driving / walking / running or what ever !! Getting a somewhat pernickity are we not ?!
Yes Sir ! Stupid term anyway
Not expensive !
