Recently I purchased wireless usb G adapters, of make Blanc.
Since purchasing this, I've noticed that my signal strength drops from
11Mbps to down to 2 Mbps.This is even when the laptop is in the same room as the router. Previous to this, I had a trendnet adapter connecting to a trendnet router, no issues.
Any thoughts on what I can do to fix this. I'm also wondering why it only shows a max signal strength of 11Mbps whereas the router is a G and with the previous adapter, I was obtaining speeds of 54Mbps.
Thank you
