Ooops. Thanks. That was the last character in a cut-and-paste, where my VIM editor on Windows habitually drops the last selected character. The missing letter wouldn't trip us up but it might trip up people unfamiliar with the default Ubuiquiti password so thanks for that admonishment.
The *second* post of that thread is really the full writeup, where I fixed the missing "t" in the login/password. The first post was just the question, but nobody helped me so I solved it on my own and have been using it every since.
One problem you brought up for Rod Speed was that a nanobeam 18dBi dish antenna of the NBE-M2-400 US (which is also known as a powerbeam) had a lousy beamwidth pattern for 150 feet whereas I'm only going about 50 feet through thick walls and the back of a bathroom mirror.
It works as an access point to the room on the other side of the thick wall and bathroom 50 feet away (maybe even a bit less than 50 feet), so I wonder why it works since you're saying the nanobeam may not even work for Rod Speed - but he needs to paint the breadth of a house while I only need to paint a roughly 20-foot square room.
I'll see if I can adapt your math to figure out why it works in such close quarters where the distance is about 30 feet to the wall, and then there is a bathroom wall facing the radio (at an angle) with the back of a mirror and a shower, and all that entails, and then ten feet from the bathroom is a room where I'm trying to feed the access point signal to.
It works. But you brought up the beamwidth issue which I had not thought of and for which I'm unfamiliar wkith the math (although I've seen the radiation pattern charts on the specification PDFs).
Am I looking at the right angle information (for both Rod and for me)?
- Page 12 of this PDF formatting link
- And pg12 of this PDF formatting linkShows a "Horizontal Azimuth" chart with an initial beam width of +/- thirty degrees.
The polar chart doesn't mention the distance to each of the six radiating circles in the diagram, but I probably am in the first circle, which means it's still at +/- thirty degrees (which is sixty degrees wide).
It works, without doing any math, but I thank you for bringing up the fact that the area painted is a function of the distance to the radio at that
60-degree wide angle.
Thanks. Yes. I agree. I don't really understand AirMax but I think it's a special Ubiquiti-only protocol between two radios. If Rod Speed has only one radio, he wants to disable AirMax which is on by default. If Rod has two radios, then maybe AirMax makes sense because it would presumably improve his connection.
